Let's say you have stored your ShadingControl in the variable shading_ctrl
In [1]: puts shading_ctrl.to_s
Out[1]:
OS:ShadingControl,
{a3e408c3-3dd3-4ea9-9c3f-b0af445a2c9d}, !- Handle
Shading Control 1, !- Name
SwitchableGlazing, !- Shading Type
{f47a3380-fc6c-4fee-b208-3e45ebf9cd82}, !- Construction with Shading Name
, !- Shading Device Material Name
, !- Shading Control Type
, !- Schedule Name
, !- Setpoint {BasedOnField A4}
, !- Shading Control Is Scheduled
, !- Glare Control Is Active
, !- Type of Slat Angle Control for Blinds
, !- Slat Angle Schedule Name
; !- Setpoint 2 {BasedOnField A4}
As can be seen above, setpoint has index 7 (it's 0-indexed, so Handle is 0, Name is 1...)
You can then use the setDouble method which accepts an index, and a double. Let's say I want to set setpoint to 25 W/m².
In[2]: shading_ctrl.setAttribute(7, 20)
Out[2]: => true
In[3]: # Let's verify
Out[3]:
OS:ShadingControl,
, !- Schedule Name
20, !- Setpoint {BasedOnField A4}
Here is an example of what NOT to do.
Indeed, Openstudio will just ignore that value and replace it with 100.
Out[1]:
OS:ShadingControl,
, !- Schedule Name
Out[2]: => true
Out[3]:
OS:ShadingControl,
, !- Schedule Name
