The daylighting controls are used to simulate, uh, daylighting controls, in an actual building. Therefore they need to be used judiciously, in spaces (and areas of those spaces) where it's anticipated there will be sufficient daylight to allow for electric lighting to be dimmed or switched off.
As David said there are two controls available per space as this emulates the "capability" of EnergyPlus. The typical use case for these things is the modeler will place one control near the perimeter and one deeper in the core, and set each control to "control" a percentage of the total electric lighting load in the space. In reality, there is one daylighting control (photosensor, what have you) in a given daylit area and the lighting is zoned and dimmed proportionally. The point is that daylighting controls as they are implemented in EnergyPlus and even OpenStudio at this point are fairly well divorced from reality. The OpenStudio team is planning to improve the daylighting control simulation modality, as are the folks at the CBEI. In the meantime you should be aware of these limitations:
As David said there are two controls available per space as this emulates the "capability" of EnergyPlus. The typical use case for these things is the modeler will place one control near the perimeter and one deeper in the core, and set each control to "control" a percentage of the total electric lighting load in the space. In reality, there is one daylighting control (photosensor, what have you) in a given daylit area and the lighting is zoned and dimmed proportionally. The point is that daylighting controls as they are implemented in EnergyPlus and even OpenStudio at this point are fairly well divorced from reality. The OpenStudio team is planning to improve the daylighting control simulation modality, as are the folks at the CBEI. CBEI. In the meantime you should be aware of these limitations:
