OpenStudio manages the EnergyPlus simulation process directly, it does not call the RunEP.bat file. OpenStudio does try to use the SqlFile as the only source for EnergyPlus results. This reduces the number of output formats that OpenStudio needs to deal with. One exception is the error file, OpenStudio does read the error file directly. OpenStudio has the ability to run Reporting Measures. These measures take the EnergyPlus simulation results and write out human readable html reports. Does that answer your question?
