EnergyPlus and OpenStudio have been moved to single sign-on solution. You will only need OpenStudio.net account. If you Click Here, it will take you to Login page and you will be able to Login with EnergyPlus. Is that what you have been doing without success?
![]() | 2 | No.2 Revision |
EnergyPlus and OpenStudio have been moved to now share a single sign-on solution. You login, you will only need OpenStudio.net account.
