Yes the use of measures should be a way I can not find in BCL this measure (it will be great to have it) Another way is to export the idf file and make changes using idf editor and run the simulation using E+ but is less convenient. My suggestion is to include a way to do it directly in OpenStudio.
click to hide/show revision 2
No.2 Revision
Yes the use of measures should be a way way.
I can not find in BCL this measure (it will be great to have it) it).
Another way is to export the idf file and make changes using idf editor and run the simulation using E+ but is less convenient. convenient.
