As you're running on linux, you had to add the parameter /disablerubyapp, needed to run SketchUp version 2014 & 2015, is also the reason why plugins don't work. Even dos2unix all the *.rb files didn't satisfy neither. Also installing under wine the new ruby versions 2.0 & 2.4 didn't solve. Got also an exit out of SU2015 by simple pas over the file-menu. As far as now best version to run on linux is the 2013. There you'll have the possibility to run ruby scripts. Greetings Xiao Shi Zi.
As you're running on linux, you had to add the parameter /disablerubyapp, needed to run SketchUp version 2014 & 2015, is also the reason why plugins don't work. Even dos2unix all the *.rb files didn't satisfy neither. Also installing under wine the new ruby versions 2.0 & 2.4 didn't solve. Got also an exit out of SU2015 by simple pas over the file-menu. As far as now best version to run on linux is the 2013. There you'll have the possibility to run ruby scripts. Having a problem with an error concerning shell32. dll
