There are number of videos available on NREL's YouTube channel. This can be good starting point, please have a look.
There are number of videos available on NREL's YouTube channel. This can be good starting point, please have a look. There is also EnergyPlus workshop coming up in Atlanta on September 28-29, 2015. You may be also look into that (if your budget allows :) ).
There are number of videos available on NREL's YouTube channel. This can be good starting point, please have a look. There is also EnergyPlus workshop EnergyPllus workshop coming up in Atlanta on September 28-29, 2015. You may be also look into that (if your budget allows :) ).
| 4 | No.4 Revision |
There are number of videos available on NREL's YouTube channel. This can be a good starting point, please have a look. There is also EnergyPllus workshop coming up in Atlanta on September 28-29, 2015. You may also look into that (if your budget allows :) ).
