If you were manually drawing the geometry you could just add three spaces each with the three space types you need to a single zone. While not published I do have a version of the bar aspect ratio measure that takes space type ratios, and creates a core and perimeter model sliced up by space type. We have done some work with blending space types but it isn't in a clean measure. But here is how I would go about it.
