The local outdoor atmospheric properties (temperature and wind speed) are calculated independently for each surface, zone, and outdoor air node. The calculations of these properties are described in the Engineering Reference here. These calculations can be controlled with coefficients of a Site:HeightVariation object.
The calculated properties can be output from the model by requesting the output variables described here.
