As Amir suggests, DOE 2.2 doesn't have a VRF model. Modeling VRFs in eQuest was discussed in a previous question on Unmet hours in Question 294 .
So, a reviewer that is asking you to validate EnergyPlus against DOE 2.2 is quite uninformed. I would try to gracefully let the reviewer know that Equest/DOE 2.2 should not be used as a reference for validating your VRF model.
