I think you will have to set the min flow sch at the zone level to 0 for these times, make the thermostat setpoints for these times to be outside the heating/cooling range (so that heating/cooling is not needed). I also think the outside air to this zone should be zero at these times, since the min flow is decided by the outside air also - but I am not sure on this - you will have to test it out. -Rohini
