Hi all,
Thanks for your quick answer Dan.
First of all, do you want me to change the tags?
Next, the truth is that i already installed manually the plugin. In http://help.sketchup.com/en/article/38583 they say that you have to install in C:\Users\YOUR USERNAME\AppData\Roaming\SketchUp. In windows i can believe, but with Wine i don't have such a folder. Howerver, i created it to chack, but nothing. So i installed in /home/user/.wine/dosdevices/c:/users/Public/Application Data/SketchUp/SketchUp 2015/SketchUp/Plugins/OpenStudio (or C:/users/Public/Application Data/SketchUp/SketchUp 2015/SketchUp/Plugins/OpenStudio).
3 "new" things: - i'm wondering if it's the name location in the OpenStudio-config.rb file that should be changes (C:\Program Files\OpenStudio 1.8.3\Ruby\openstudio). I tried some options, such as c:/Program\ Files/OpenStudio\ 1.8.3/Ruby/openstudio, but still don't have nothing). - the new manually installation generated a new error message i had a few days ago, when i first tried the installation: Error loading OpenStudio Sketchup Plug-In: 998: No access to memory location: -C:/Program Files/OpenStudio 1.8.3/Ruby/openstudio/openstudioutilitiescore.so > this files is in the indicated folder; i wonder if it's a question of library, etc.?
Well, thanks again if someone has an idea... And thanks Dan for your quick answer!
Regards,
Mathieu
