Thank you very much! I have created the object: InternalSource, LowTemperatureRadiant:VariableFlow and a Thermostat.
Do I need to implement the whole HVAC System (PlantLoop, etc.)? I am new to EnergyPlus and OpenStudio and I tried it in OS, but it is not that easy - besides, we don't need the whole HVAC in our model, just concrete core activation incl. measured supply temperature.
Is there a possibility, to model something like a "ideal source/sink" for the LowtemperatureRadiant + Construction:InternalSource - without the wohle HVAC system?
Thank you very much
Is there a possibility, to model something like a "ideal source/sink" for the LowtemperatureRadiant + Construction:InternalSource - without the wohle HVAC system? And if so, how would be a proper way to do that (inside OS would be easier for the start).
Thank you very much
