The EnergyPlus v8.3 IDD file gives a default of 0.4 for the Building object Temperature Convergence Tolerance Value field and 0.04 for the Loads Convergence Tolerance Value field. So yes, 0.4 is a proper value.
The EnergyPlus v8.3 IDD file gives a default of 0.4 for the Building object Temperature Convergence Tolerance Value field and 0.04 for the Loads Convergence Tolerance Value field. So yes, 0.4 is a proper value.value for temperature convergence.
