The report variable representing the latent cooling energy or rate describes system performance with regard to moisture energy transfer. There are multiple reports for the ideal loads air system. The cooling components of latent heat transfer are shown below.
Zone Ideal Loads Supply Air Latent Cooling Rate [W]
Zone Ideal Loads Zone Latent Cooling Rate [W]
Zone Ideal Loads Outdoor Air Latent Cooling Rate [W]
The calculations for latent performance are similar for each of these reports. The total enthalpic energy transfer rate is calculated and then the sensible (temperature) component is subtracted from this value. This value is reported regardless of humidistat usage.
Q_Lat = Mdot * ( Hsupply - Hmixedair ) - Qsen
Q_Lat Qlat = [ Mdot * ( Hsupply - Hmixedair ) ] - Qsen
where:
Mdot = zone air mass flow rate
Hsupply = ideal loads air system output directed to thezone
Hmixedair = air enthalpy entering the ideal loads air system (including outdoor air)
Qsens = Mdot * Cp * (Tzoneinlet - Tzone)
| 4 | No.4 Revision |
Qsens
where:
| 5 | No.5 Revision |
Qlat $$Q_{lat}
= [where, $\dot{m}$ is the
zone air mass flow | 6 | No.6 Revision |
$$Q_{lat} = [ \dot{m} * ( H_{supply} - H_{mixedair} ) ] - Q_{sens}$$
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$.
| 7 | No.7 Revision |
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}$$Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$.(T_{zoneinlet}-T_{zone})$$.
| 8 | No.8 Revision |
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$$.$$Q_{sens}=\dot{m}.c_p.(T_{zoneinlet}-T_{zone})$$.
| 9 | No.9 Revision |
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}.c_p.(T_{zoneinlet}-T_{zone})$$.$$Q_{sens}=\dot{m}.c_p*(T_{zoneinlet}-T_{zone})$$.
| 10 | No.10 Revision |
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}.c_p*(T_{zoneinlet}-T_{zone})$$.$$Q_{sens}=\dot{m}c_p(T_{zoneinlet}-T_{zone})$$.
| 11 | No.11 Revision |
$$Q_{lat} = [ \dot{m} * \times ( H_{supply} - H_{mixedair} ) ] - Q_{sens}$$
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}c_p$$Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$$.
| 12 | No.12 Revision |
$$Q_{lat} = [ \dot{m} \times ( H_{supply} - H_{mixedair} ) ] - Q_{sens}$$
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $$Q_{sens}=\dot{m}\times $Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$$.(T_{zoneinlet}-T_{zone})$.
| 13 | No.13 Revision |
where, $\dot{m}$ is the zone air mass flow rate, rate,
$H_{supply}$ is the ideal loads air system output directed to the zone, zone,
$H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$.
| 14 | No.14 Revision |
where, $\dot{m}$ is the zone air mass flow rate, $H_{supply}$ is the ideal loads air system output directed to the zone, $H_{mixedair}$ is the air enthalpy entering the ideal loads air system (including outdoor air) and $Q_{sens}=\dot{m}\times c_p \times (T_{zoneinlet}-T_{zone})$.
| 15 | No.15 Revision |
where,
rate,/s/s
| 16 | No.16 Revision |
where,
$\dot{m}$ is the zone air mass flow rate,/s/s
rate,
zone,
| 17 | No.17 Revision |
where, where:
