click to hide/show revision 1
initial version
Hello Meg,
When you run efficiency measures in Sketchbox, each measure includes the changes of all the measures run above it. For example, if you have three efficiency measures, the results of the first measure reflect the changes you made in the first measure; the second measure results include the changes of both the first and second measures, and so on.
  • Drew Morrison
