I believe you want to use the Residential Quota Downselect Sampler in your project yml file. It gives you the ability to specify Parameter|Option logic statements, as well as control over resampling.
(Note that at this time the residential_quota_downselect sampler with resample is not supported when running a project using run_analysis.rb.)
