If I understand correctly, you changed the IDF timestep to hourly but used the same 15-min stochastic schedule CSV. If you want to run an hourly simulation, it'd be better to re-generate the ResStock model using an hourly timestep (it can be changed here for example) so that the stochastic schedule CSV is also regenerated hourly.
