@MrBlue,
Not a DB user, but with EnergyPlus it really boils down to pinpointing reasonable blended values for each material layer in the mix (depending on moisture content) - see ref:
That's a start. With variable moisture content, you could explore more advanced EnergyPlus options. Hope this helps.
