Hello, Mohcine. I think you can learn the input maros, one of auxiliary programs supported in Energyplus. You can reference a outer file (here is your BSDF defination) and set the WindowMaterial:Glazing Optical Data Type = BSDF, then create Construction:ComplexFenestrationState to use it and control in EMS. Hope this feature can help you!
