You can make work efficiency, clothing insulation, and air velocity schedules in the GUI as shown below. You will likley need to change the default schedule values that appear when you first make the new schedule.
Then you will see them as choices in the measure. the measure only shows schedules of the correct type limits for each argument.
Then you will see them as choices in the measure. the The measure only shows schedules of with the correct type limits for each argument.
