Hi, sorry for not noticing this question earlier.
In case you haven't found a solution, I think the problem is with the invalid file names in the second and third columns, which read "....\null". They are supposed to reference the model and weather files. However, you can use index numbers instead of file paths, e.g. "TR_G-alt_1-Use_0272-Nabs_1-mass_sch-size_080_SoSchu0_roo1_TGA1_vent0_rot045_wetPari,0,0,1,300,0272,1,sch,080,1,1,0,45,Pari,75"
In regard to generating a random number for each case, jEPlus's @calc syntax may help. You can use @calc(Math.floor(Math.random() * 10)), for example, to get numbers 0 ~ 9.
Yi
