Yes. the object has an input field for "source zone" and "zone name". the zone name is the name of the zone receiving the air. And the source zone is the zone providing the air.
In your case, You would have 4 ZoneMixing object. One in each of the receiving zones, with the source zone always being the transmitting zone.
You could also just use and air loop. You did say that the air is ducted, which must mean there is a fan?
You could also just use and an air loop. You did say that the air is ducted, which must mean there is a fan?
