Thank you! atmos_data is now complete, I corrected the file destination, which was indeed the problem.
I would also like some help with the results I obtained, the command below represents a cloudy sky mid-latitude (same location).
genssky 12 21 12 -a 53.466 -o 2.2333 -m 0 -n 4 -r 256 -c 1 -f test_hsr.hsr > ssky.rad
after the octree, I used:
echo 0 0 0 0 0 1 | rtrace -ab 8 -ad 16384 -as 4096 -co+ -cs 20 ssky.oct
If I plot it I have a spectral profile (20 samples) high at the end of the spectrum. This is an overcast sky, so I was expecting a rather uniform profile (higher at shorter wavelengths) and not that high values, as I'm assuming is W/m² perhaps I need to normalize it but not sure against what.
I add the plot with -c 0 just to compare, but resulted in similar profiles.
I'd appreciate any comments, thank you!
-Steph
genssky gensky 12 21 12 -a 53.466 -o 2.2333 -m 0 -n 4 -r 256 -c 1 -f --f test_hsr.hsr > ssky.rad
sky.oct
-Steph
