Field: Rated Relative Humidity
This field is ONLY used if the Capacity Rating Type is CapacityTotalSpecificConditions and represents the relative humidity at rated conditions, expressed as a percent. The default is 85.
This explains why RH is the same when assign different value of the rated RH
