Simulating a model in a different location/climate is not as simple as selecting a different EPW. You also need to modify the following objects in the IDF to reflect the new location:
Site:Location
SizingPeriod:DesignDay (cooling and heating design days)
Site:WaterMainsTemperature (if applicable)
Site:GroundTemperature (if applicable)
Also, if your HVAC is hard-sized (meaning capacities/flows are specified with numbers, instead of "Autosize"), you may need to either change these to Autosize or consider re-sizing your equipment to reflect the capacities appropriate for the new location(s).
By the way, the Drive link you shared is restricted, consider changing its permissions to "anyone with the link".
