I suggest going at this in steps (e.g. make sure your model first works with TABS, then look at integrating GHX).
Peruse through the OpenStudio-Resources simulation tests: CTRL-F "low" (3 hits - only 2 offering cooling):
Each example holds 3 files:
Both the .rb and .py files are structured and commented so you get a sense of required items, step-by-step logic/implementation, etc. You can open the example .osm files using the OpenStudio Application, go over the plant/system layouts, run simulation tests, etc., before attempting adaptations to your model.
You can eventually do the same for GSHP: CTRL-F "ghx".
Hope this helps ...
