As suggested in response to one of your previous posts, change the following Source Variable entry in both UtilityCost:Charge:Simple objects in the IDF ("totalEnergy", not "Electricity:Facility"):
UtilityCost:Charge:Simple,
EnergyChargeElectric, !- Utility Cost Charge Simple Name
Electricity Tariff, !- Tariff Name
totalEnergy, !- Source Variable ... not "Electricity:Facility" !
Annual, !- Season
EnergyCharges, !- Category Variable Name
0.077; !- Cost per Unit Value or Variable Name
EnergyChargeGas, !- Utility Cost Charge Simple Name
Gas Tariff, !- Tariff Name
totalEnergy, !- Source Variable ... not "NaturalGas:Facility" !
Annual, !- Season
0.0278; !- Cost per Unit Value or Variable Name
This will generate the following in the generated eplustbl.htm file:
To get kWh outputs (if desired), change the following prior to running the simulation:
OutputControl:Table:Style,
CommaAndHTML, !- Column Separator
JtoKWH; !- Unit Conversion
There's an outstanding issue with the following IDF entry:
Output:Meter,
Facility Total Cost, !- Key Name
hourly; !- Reporting Frequency
This generates the following in the eplusout.err file:
** Warning ** Output:Meter: invalid Key Name="FACILITY TOTAL COST" - not found.
Check the generated eplusout.mdd file for admissible output meters.
EnergyPlus output variables and meters are usually reserved for physical quantities (e.g. degC, kg/s, W, J). As your tariff is straightforward (0.077 $/kWh), maybe simpler to post-process hourly "Electricity:Facility" outputs in the generated eplusout.eso file:
This would at least give you a time series of hourly utility costs ... based on kWh only! Utility costs are usually a tad more complex (e.g. demand charges), which is why they are typically aggregated and reported monthly (and/or annually).
Annual, !- Season
Annual, !- Season
This will generate generates the following in the generated eplustbl.htm file:
Output:Meter,
This would at least give you a time series of hourly utility costs ... based on kWh only! Utility costs are usually a tad more complex (e.g. demand charges), which is why they utility costs are typically aggregated and reported monthly (and/or annually).
Annual, !- Season
Annual, !- Season
This generates the following in the eplustbl.htm file:file (or .html file):
Output:Meter,
meters. Run time energy costs aren't there. EnergyPlus output variables and meters are usually reserved for physical quantities quantities (e.g. degC, kg/s, W, J). As However, as your tariff is straightforward (0.077 $/kWh), maybe it's simpler for you to post-process hourly "Electricity:Facility" outputs in the generated eplusout.eso file:
This would at least give you a time series of hourly utility costs ... based on kWh only! Utility costs are usually a tad more complex (e.g. demand charges), which is why utility costs are typically aggregated and reported monthly (and/or annually).
| 4 | No.4 Revision |
Annual, !- Season
Annual, !- Season
This generates the following in the eplustbl.htm file (or .html .html file):
EDIT: Not sure which .html file here (your recent screen capture) corresponds to the usual eplustbl.htm file:
Output:Meter,
Check the generated eplusout.mdd file for admissible output meters. Run time energy costs aren't there. EnergyPlus output variables and meters are usually reserved for physical quantities (e.g. degC, kg/s, W, J). However, as your tariff is straightforward (0.077 $/kWh), maybe it's simpler for you to post-process hourly "Electricity:Facility" outputs in the generated eplusout.eso file:
| 5 | No.5 Revision |
Annual, !- Season
Annual, !- Season
This generates the following in the eplustbl.htm file (or .html file):
EDIT: Not sure which .html .html file here (your recent screen capture) corresponds to the usual eplustbl.htm file:
Output:Meter,
