Hi Anurag, why don't you dedicate the zone groups per VRF OU?
If you want multiple VRF OU to serve the same zone (not zone group), then I would break up the zone into multiple zones, and the dedicate the VRF OUs to the associated zones. You could use virtual partitions and ensure interzone airflow for mixing.
