Thank you very much Scott, that helped a lot.
The challenge is that the Energyplus Input Output Reference does not have complete items for the ElectricLoadCenter:Distribution.
However, I found out a good example, LrgOff_GridStorageScheduled.idf, from NREL GitHub. This IDF is formulated for the grid with no generation component inside. Then I found out another example for PV excess generation from NREL GitHub. Then, I carefully mixed these 2 IDFs with my problem characteristics.
Thanks very much for your time and assistance. Sincerely, Behnam Mohseni Gharyehsafa Maynooth, Ireland
