@Manny, there are 13 Output:Variable requests in the IDF you shared. But as a few are redundant entries, there are really only 8 unique requests:
Output:Variable,
*, !- Key Value
Zone Thermal Comfort Fanger Model PMV, !- Variable Name
hourly, !- Reporting Frequency
Always On Discrete; !- Schedule Name
Output:Variable,
*, !- Key Value
Zone Thermal Comfort Fanger Model PPD, !- Variable Name
Output:Variable,
*, !- Key Value
Zone Heating Electricity Energy, !- Variable Name
Output:Variable,
*, !- Key Value
Zone Cooling Electricity Energy, !- Variable Name
Output:Variable,
*, !- Key Value
InteriorLights:Electricity, !- Variable Name
Output:Variable,
RefPoint_Center, !- Key Value
Daylighting Reference Point 1 Illuminance, !- Variable Name
Hourly, !- Reporting Frequency
Output:Variable,
*, !- Key Value
Facility Total Purchased Electric Energy, !- Variable Name
hourly; !- Reporting Frequency
Output:Variable,
*, !- Key Value
Facility Total Purchased Gas Energy, !- Variable Name
These 4 variables are successfully being reported in the eplusout.eso file:
Search the eplusout.err file for failed ones, e.g.:
** Warning ** The following Report Variables were requested but not generated -- check.rdd file
** ~~~ ** Either the IDF did not contain these elements, the variable name is misspelled,
** ~~~ ** or the requested variable is an advanced output which requires Output : Diagnostics, DisplayAdvancedReportVariables;
************* Key=*, VarName=ZONE HEATING ELECTRICITY ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE COOLING ELECTRICITY ENERGY, Frequency=Hourly
etc.
Heating & Cooling: The single zone in the model ("Thermal Zone 1") is served by an IdealLoadsAirSystem. As such, there is neither electric heating nor electric cooling energy use in your model. Zone heating and cooling requirements are reported as District Heating and District Cooling (see eplustbl.htm file). Search the generated eplusout.rdd file for:
... probably pick these instead.
Daylighting: I simply replaced "RefPoint_Center" with an " " - now getting realistic numbers in the *eplusout.eso file. The eplusout.err holds additional warnings on daylighting parameters - these should help pinpointing underlying issues with your model vis-à-vis daylighting.
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
** ~~~ ** misspelled, or the the
requested variable is an advanced output which requires requires
etc.
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Either the IDF did not contain these elements, the variable name is misspelled, or the
etc.
Heating & Cooling: The single zone in the model ("Thermal Zone 1") is served by an IdealLoadsAirSystem. As such, there is neither electric heating nor electric cooling energy use in your model. Zone heating and cooling requirements are reported as District Heating and District Cooling (see "end uses" in the eplustbl.htm file). Search the generated eplusout.rdd file for:
Daylighting: I simply replaced "RefPoint_Center" with an " " - now ". Now getting realistic numbers in the *eplusout.eso file. The eplusout.err holds additional warnings on daylighting parameters - these should help in pinpointing underlying issues with your model vis-à-vis daylighting.
| 4 | No.4 Revision |
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
etc.
Heating & Cooling: The single zone in the model ("Thermal Zone 1") is served by an IdealLoadsAirSystem. As such, there is neither electric heating nor electric cooling energy use in your model. Zone With ideal loads, zone heating and cooling requirements are instead reported as District Heating and District Cooling (see "end uses" in the eplustbl.htm file). Search the generated eplusout.rdd file for:
Daylighting: I simply replaced "RefPoint_Center" with an " ". Now getting realistic numbers in the *eplusout.eso file. The eplusout.err holds additional warnings on daylighting parameters - these should help in pinpointing underlying issues with your model vis-à-vis daylighting.
| 5 | No.5 Revision |
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
etc.
Heating & Cooling: The single zone in the model ("Thermal Zone 1") is served by an IdealLoadsAirSystem. As such, there is neither electric heating nor electric cooling energy use in your model. With ideal loads, zone heating and cooling requirements are instead reported as District Heating and District Cooling (see "end uses" in the eplustbl.htm file). Search the generated eplusout.rdd file for:
Daylighting: I simply replaced "RefPoint_Center" with an " * ". Now getting realistic numbers in the *eplusout.esoeplusout.eso file. The eplusout.err holds additional warnings on daylighting parameters - these should help in pinpointing underlying issues with your model vis-à-vis daylighting.
| 6 | No.6 Revision |
@Manny, there are 13 Output:Variable requests in the IDF you shared. But as a few are redundant entries, there are really only 8 10 unique requests:
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, Lights Electric Energy, Hourly;
Output:Variable,
*, Zone Lights Illuminance at Reference Point, Hourly;
These The following 4 variables are successfully being reported in the eplusout.eso file:
etc.
Daylighting: I simply replaced "RefPoint_Center" with an " * ". Now getting realistic numbers in the eplusout.eso file. The eplusout.err holds additional warnings on daylighting parameters - these should help in pinpointing underlying issues with your model vis-à-vis daylighting.
| 7 | No.7 Revision |
@Manny, there are 13 Output:Variable requests in the IDF you shared. But as a few are redundant entries, there are really only 10 unique requests:
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
The IDF also hold 8 Output:Meter requests - some are also redundant (e.g. 3 separate "Electricity:Facility" requests). In the end, the following 4 variables variables/meters are successfully being reported in the eplusout.eso file:
The reported "Electricity:Facility" and "InteriorLights:Electricity" are in fact Output:Meter instances - not Output:Variable instances. For instance, there are 2 "InteriorLights:Electricity" entries in the IDF:
In the end, it's the Output:Meter "InteriorLights:Electricity" that's being reported in the ESO file - not the Output:Variable of the same name. Search the eplusout.err file for failed remaining (failed) ones, e.g.:
etc.
| 8 | No.8 Revision |
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
The IDF also hold 8 Output:Meter requests - some are also redundant (e.g. 3 separate "Electricity:Facility" requests). In the end, the following 4 variables/meters are successfully being reported in the eplusout.eso file:
In the end, it's the Output:Meter "InteriorLights:Electricity" that's being reported in the ESO file - not the Output:Variable of the same name. Search the eplusout.err file for remaining (failed) ones, e.g.:
etc.
EDIT
Utility Costs: Hadn't taken a deeper dive on the Utility:Costs issues, as reported in the generated eplusout.err file - my bad! I must admit, I have rarely used Utility:Cost instances - I usually post process results using bespoke scripts. I suggest incrementally building up something useful/testable, based on the documentation here and examples here. For instance, the following in the IDF you shared could be as follows:
UtilityCost:Charge:Simple,
EnergyChargeElectric, !- Utility Cost Charge Simple Name
Electricity Tariff, !- Tariff Name
totalEnergy, !- Source Variable
Annual, !- Season
EnergyCharges, !- Category Variable Name
0.105; !- Cost per Unit Value or Variable Name
Note the "totalEnergy" as Source Variable and "Annual" as Season. This works when tested.
| 9 | No.9 Revision |
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
*, !- Key Value
Output:Variable,
*, !- Key Value
Output:Variable,
Output:Variable,
etc.
EDIT
Utility Costs: Hadn't taken a deeper dive on the Utility:CostsUtility:Cost issues, as reported in the generated eplusout.err file - my bad! I must admit, I have rarely used Utility:Cost instances - I usually post process results using bespoke scripts. I suggest incrementally building up something useful/testable, based on the documentation here and examples here. For instance, the following in the IDF you shared could be as follows:
Annual, !- Season
