If it helps anyone, I have found a satisfying solution, I don't know if it is state of the art, but it achieves my goals.
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAMCALLINGMANAGER ===========
EnergyManagementSystem:ProgramCallingManager, WarmupFlagCaller, !- Name AfterNewEnvironmentWarmUpIsComplete, !- EnergyPlus Model Calling Point WarmupFlagProgram; !- Program Name 1
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAM ===========
EnergyManagementSystem:Program, WarmupFlagProgram, !- Name SET WarmupFlagProxy = 1; !- Program Line 1
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:GLOBALVARIABLE ===========
EnergyManagementSystem:GlobalVariable, WarmupFlagProxy; !- Erl Variable 1 Name
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:OUTPUTVARIABLE ===========
EnergyManagementSystem:OutputVariable, WarmUpFlagEP, !- Name WarmupFlagProxy, !- EMS Variable Name Averaged, !- Type of Data in Variable ZoneTimestep; !- Update Frequency
!- =========== ALL OBJECTS IN CLASS: EXTERNALINTERFACE:FUNCTIONALMOCKUPUNITIMPORT:FROM:VARIABLE ===========
ExternalInterface:FunctionalMockupUnitImport:From:Variable, EMS, !- Output:Variable Index Key Name WarmUpFlagEP, !- Output:Variable Name agentFMU.fmu, !- FMU File Name FMI, !- FMU Instance Name WarmUpFlag; !- FMU Variable Name
