Because I use the model in OpenStudio only for the client to see the model geometry and constructions, It become a must that all the wall could be check.
I found that there is another way to add windows to a wall by adding it relative to the wall. you give the the starting difference from the beginning of the surface, length and height and you do not need to be bother by the exact slop. this solved the issue for me
Window,
0:APT1_Window_83_1_11_97,!- Name
_6-12-6 4.8 - 1002, !- Construction Name
0:APT1_Wall_83_1_11, !- Building Surface Name
, !- Frame and Divider Name
1, !- Multiplier
0.39, !- Starting X Coordinate {m}
0.01, !- Starting Z Coordinate {m}
2.8, !- Length {m}
2.3; !- Height {m}
