NOT AN ANSWER
Seems I had an attachment limit on the original post. Please see attached idf file. Please remove the .jpg extension then unzip. Had to do both these things to get it to upload.C:\fakepath\on-grade-vert-perim-insul-fails.zip.jpg
NOT AN ANSWER
Seems I had an attachment limit on the original post. Please see attached idf file. Please remove the .jpg extension then unzip. Had to do both these things zipping (size reduction) and renaming to get it to upload.C:\fakepath\on-grade-vert-perim-insul-fails.zip.jpg
