Lights can be defined as a lighting power density or within a lighting system. The lighting system method allows the entry of luminaire types and the quantity of each type in the space. Each lighting system can be assigned to a daylit area type for use with daylighting controls: Skylit, the portion of the floor that receives daylight from a skylight; Primary Sidelit, portion of the floor that receives the highest amount of daylight from a window; Secondary Sidelit, portion of the floor that receives a lower, but still useful, amount of light from a window; or none for that portion of the space which is not daylit.
