The sensor is the coil outlet air node temperature and the actuator is the coil water-side inlet node.
Controller:WaterCoil,
Central Cooling Coil Contoller 1, !- Name
Temperature, !- Control Variable
Reverse, !- Action
FLOW, !- Actuator Variable
Main Cooling Coil 1 Outlet Node, !- Sensor Node Name
Main Cooling Coil 1 Water Inlet Node, !- Actuator Node Name
0.002, !- Controller Convergence Tolerance {deltaC}
autosize, !- Maximum Actuated Flow {m3/s}
0.0; !- Minimum Actuated Flow {m3/s}
The sensor is the coil outlet air node temperature and the actuator is the coil water-side inlet node.node. The set point manager would be placed at the outlet node of the coil.
Reverse, !- Action
