Thank you for your answer. Your suggestion OnNigthAndOnDayIfHighOutdoodAirTemperatureAndHighSolarOnWindow solves only partially the issue, usually during summer time at night the shade should be Off and not On. Using OnIfSchedulleAllows using two schedules (one for winter nights an other for summer day) is an option but is necessary to determine with some preliminary calculation the winter and summer season: Schedule control type similar to: On Night If Low external temperature, On Day If High External Temperature, Else Off Could be better approach. In addition, during “fresh” night the shade covers 100% of the window but during “hot” days the shade covers only x% of the window. Someone has some idea how to model this kind of shading? I’ve tried to do it using two calculations one for “winter” shading and a second one with “summer” shading and then mixing results but it requires too many work.
