I think what you're looking for is the ElectricEquipment object's End-Use Subcategory field which will create a new row in the End Uses by Subcategory table in the tabular output HTML file.
In OpenStudio this field can be found in each instance of the object but is not editable as of 1.8.2. The easiest way to edit the field is in the SketchUp Plugin through the Inspector.
In OpenStudio this field can be found in each instance of the object but is not editable as of 1.8.2. 1.8.2. The easiest way to edit the field is in the SketchUp Plugin through the Inspector.
I think what you're looking for is the ElectricEquipment object's End-Use Subcategory field which will create a new row in the End Uses by Subcategory table in the tabular output HTML file.file. Additionally, a row will be created in the Energy Meters table for each subcategory you create.
| 4 | No.4 Revision |
I think what you're looking for is the ElectricEquipment object's End-Use Subcategory field which will create a new row in the End Uses by Subcategory table in the tabular output HTML file. Additionally, a row will be created in the Energy Meters table for each subcategory you create.
| 5 | No.5 Revision |
In OpenStudio By default this field is set to "General" and can be found in OpenStudio in each instance of the object but is not editable as of 1.8.2. The easiest way to edit the field is in the SketchUp Plugin through the Inspector.
