The outdoor temperature does not affect the operation of your cooling system. Cooling is activated only when the zone temperature exceeds your thermostat setpoint. Your thermostat schedules are not consistently set to 23°C. Instead, you use schedules with priotities, with specific settings for weekends: on Saturdays, the thermostat is set to 24°C with a setback of 26.7°C, while on Sundays, it is set to 26.7°C. Since June 3rd and 4th fall on Saturday and Sunday, respectively, these schedule differences explain the observed temperatures.
