@wala.beliah
Firstly, you can try importing the .idf with the AFN back into OpenStudio however I'm really not sure if OpenStudio can read airflow networks from .idfs. None the less I suggest that you try this first.
At the time of writing the Building Components Library website appears to be down, I do believe that there is an example measure or components there with Air flow networks. Please check back later to take a look.
Alternatively I suggest that you check out the pollination discord there there should be some examples of using the OpenStudio SDK to build up a airflow network there in a measure.
Lastly you can try to build a measure using the OpenStudio SDK yourself at: https://openstudio-sdk-documentation.s3.amazonaws.com/index.html
@wala.beliah
Firstly, you can try importing the .idf with the AFN back into OpenStudio however I'm really not sure if OpenStudio can read airflow networks from .idfs. .idfs at the time of writing.
At the time of writing the Building Components Library website appears to be down, I do believe that there is an example measure or components there with Air flow networks. Please check back later to take a look.look. This is a good starting point if you cannot import the .idf into OpenStudio.
Alternatively I suggest that you check out the pollination discord there discord there should be some examples of using the OpenStudio SDK to build up a airflow network there in a measure.
@wala.beliah
Firstly, you can try importing the .idf file with the AFN back into OpenStudio however OpenStudio. However, at the time of writing, I'm really not sure if OpenStudio can read airflow networks from .idfs at the time of writing. .idf files.
At the time of writing Currently the Building Components Library website appears to be down, I do believe that there is an example measure or components there with Air flow networks. Please check back later to take a look. This is a good starting point if you cannot import the .idf into OpenStudio.
Alternatively I suggest that you check out the pollination discord there should be some examples of using the OpenStudio SDK to build up a airflow network there in a measure.
