If there are questions that you feel should be removed from the site entirely and you don't have enough karma to remove the question yourself, you can email unmethours@bigladdersoftware.com and someone will clean it up.
If there are questions that you feel should be removed from the site entirely and you don't have enough karma to remove close the question yourself, you can email unmethours@bigladdersoftware.com and someone will clean it up.
If there are questions that you feel should be removed and you don't have enough karma to close the question yourself, you can email unmethours@bigladdersoftware.com and someone will clean it up.
Closed questions will remain on the site, but they shouldn't show up when filtering.
