The ZoneHVAC:TerminalUnit:VariableRefrigerantFlow may be used in the outdoor air system. See the IO Reference doc for this object.
"The VRF terminal unit may be used as zone, air loop or outside air system equipment."
For the fields that specify a fan, e.g., Supply Air Fan Object Type and Supply Air Fan Object Name:
"This field may be left blank when the VRF terminal unit is used as air loop or outdoor air system
equipment."
equipment."
| 4 | No.4 Revision |
"This field may be left blank when the VRF terminal unit is used as air loop or or
outdoor air system
system equipment."
equipment."
