I would say if you are new to EnergyPlus, Openstudio is a little more intuitive when it comes to adding HVAC, so you might want to start there and yes you can export the idf for OS to E+ for running. When you are in OS, go to export and export as an idf. Then open that idf in E+ and you have your E+ file ready to go. - Annie
