Getters follow the convention of being called get<ClassName>s().
The class is called FuelFactors. Note the existing s.
So logically, the getter is getFuelFactorss() (double s).
The same goes for getLightss().
TL;DR: Getters follow the convention of being called get<ClassName>s().
If you want an explanation you didn't ask for, this is because we're using a C++ template: https://github.com/NREL/OpenStudio/blob/09472be58fa387840d7e07f93e41f4da97294478/src/model/Model.hpp#L469-L470
template <typename T>
std::vector<T> getModelObjects(bool sorted = false);
This exposed to the target language via SWIG bindings, and we transform that to a method called get<T>s() automatically.
The same is true for the ruby IdfObject.to_ClassName(). The C++ equivalent is template<typename T> boost::optional<T> IdfObject::cast()
Here are all of the similar std::vector<T> get<T>s() that end with at least a double s, from python
import openstudio
import re
import inspect
RE_GET = re.compile(r'^get.+ss$')
getters = []
model = openstudio.model.Model()
for method_name in dir(model):
method = getattr(model, method_name)
if not inspect.ismethod(method):
continue
if not RE_GET.match(method_name):
continue
if not len(inspect.signature(method).parameters) == 0:
continue
getters.append(method_name)
['getAdditionalPropertiess',
'getAirLoopHVACUnitaryHeatCoolVAVChangeoverBypasss',
'getAirflowNetworkDuctViewFactorss',
'getAirflowNetworkReferenceCrackConditionss',
'getCoilHeatingGass',
'getCoolingTowerPerformanceCoolToolss',
'getDefaultSubSurfaceConstructionss',
'getDefaultSurfaceConstructionss',
'getElectricLoadCenterInverterPVWattss',
'getExteriorLightss',
'getFuelFactorss',
'getGass',
'getGeneratorPVWattss',
'getHumidifierSteamGass',
'getInternalMasss',
'getLightss',
'getMaterialPropertyMoisturePenetrationDepthSettingss',
'getMaterialPropertyPhaseChangeHysteresiss',
'getOutputEnvironmentalImpactFactorss',
'getRefrigerationDefrostCycleParameterss',
'getRunPeriodControlSpecialDayss',
'getScheduleTypeLimitss',
'getSurfacePropertyConvectionCoefficientss',
'getSurfacePropertyGroundSurfacess',
'getSurfacePropertyOtherSideCoefficientss',
'getSurfacePropertySurroundingSurfacess',
'getWaterUseConnectionss',
'getWeatherFileDayss'
| 4 | No.4 Revision |
import openstudio
import re
import inspect
getters = []
continue
continue
# Keep only those that take zero params
if not len(inspect.signature(method).parameters) == != 0:
continue
'getFuelFactorss',
'getGass',
'getInternalMasss',
'getLightss',
