In the "Input Verification and Results Summary" report of the EnergyPlus tabular output there is a table called "Zone Summary". While not as detailed as what you get about lighting in the "Lighting Summary" Section, you can see electric power density by thermal zone. The table also includes lighting an occupancy density along with geometric and other information about the thermal zone.
You can also look under the "Energy Meters" report in the "Annual and Peak Values - Electricity" table. This provides consumption and peak load. It includes more than plug loads. If you are using OpenStudio 1.8.1 or later our default simulation report filters out just the plug load from this to create the "Plug Loads Summary" section.
You can also look under the "Energy Meters" report in the "Annual and Peak Values - Electricity" table. This provides consumption and peak load. It includes more than plug loads. If you are using OpenStudio 1.8.1 or later our default simulation report filters out just the plug load from this to create the "Plug Loads Summary" section. If you are using OpenStudio 1.7.5 or later you can download that measure from the BCL.
