You can use combinations of insulation from the material library that add up to the desired R-value.
You will need to select a material from the library with similar thermal properties to the material being used. You can use combinations of insulation from find the material library that add up to in spreadsheet form as part of the desired R-value. CBECC-Com installation in the C:\Users(your username)\Documents\CBECC-Com 2013 Data\Documents\RulesetSource\CEC 2013 Nonres\Rules\Tables folder of your computer.
