Can reproduce the crash with OpenStudioApplication v1.8.0 (App), when accessing the Geometry tab for instance.
However, one can set an EPW/DDY pair and attempt a launch with the App. The App doesn't crash - it (safely) hals its forward translation to EnergyPlus and reports the same OpenStudio CLI failure discussed here (missing thermal zone ports). The fix discussed in the link should work.
If you do succeed in fixing the OSM, you should consider filing an issue - the App shouldn't crash. This seems to be a recurring thing (see here and here).
Hope this helps.
However, one can set an EPW/DDY pair and attempt a launch with the App. The App doesn't crash - it (safely) hals its halts forward translation to EnergyPlus and reports the same OpenStudio CLI failure discussed here (missing thermal zone ports). The fix discussed in the link should work.
Hope this helps.
However, one can set an EPW/DDY pair and attempt a launch with the App. The App doesn't crash - it (safely) halts forward translation to EnergyPlus and reports the same OpenStudio CLI failure discussed here (missing thermal zone ports). The fix discussed in the link should work.
If you do succeed in fixing fixing/running the OSM, you should consider filing an issue (possibly two):
Hope this helps.
| 4 | No.4 Revision |
If you do succeed in fixing/running the OSM, you should consider filing an issue (possibly two):
Hope this helps.
