Not a definitive answer - too long for a comment.
@Zakaria, I had initially posted a generic answer on how to output coil air inlet node temperatures (see below). But refrigeration systems are a bit different. For instance, based on the system described here, a ZoneHVAC:RefrigerationChillerSet's air inlet node name is unused:
Not used, reserved for future use. Current version exchanges energy directly with the zone, external of any air system.
This boils down to the zone air node. Check the .rdd file for related output variables. Hope this helps.
Initial, generic solution for coils. Coils have both inlet and outlet air nodes.
Output:Variable,*,System Node Temperature,hourly; !- HVAC Average [C]* with the coil "Field: Air Inlet Node Name" | 2 | No.2 Revision |
Output:Variable,*,System Node Temperature,hourly; !- HVAC Average [C]* with the coil "Field: Air Inlet Node Name"EDIT: Follow-up based on shared IDF. The AirChiller.idf file has the following entry:
Output:Variable,
NODE_4, !- Key Value
System Node Temp, !- Variable Name
Timestep; !- Reporting Frequency
The .err file reports an issue with this. It should be System Node Temperature:
Output:Variable,
System Node Temperature, !- Variable Name
Once fixed, the .eso files tracks the requested node temperature. I then replaced NODE_4 with *. There are only 5 node temperature time series being tracked (from the .eso file):
7,1,ZN,Zone Outdoor Air Drybulb Temperature [C] !TimeStep
195,1,ZN,Zone Air Temperature [C] !TimeStep
307,1,NODE_4,System Node Temperature [C] !TimeStep
308,1,NODE_5,System Node Temperature [C] !TimeStep
309,1,CONDENSER OUTDOOR AIR NODE,System Node Temperature [C] !TimeStep
Spot checked a dozen periods over the year:
... e.g.:
2,1, 8,10, 0,13,50.00,51.00,Thursday
7,31.445974999562816
195,-18.17873918169955
307,-18.17873918169955
308,-18.17874294489641
309,31.445
I have to defer to more knowledge people when it comes to refrigeration units, but I suspect (from what I'm reading) that one cannot isolate coil air inlet vs outlet temperatures. Good news:
