This is likely be an extra semi-colon on line 79649 of your IDF that precedes "Cooling Coil Electricity Energy" on line 79650 that the severe error message mentions.
For example, unless you have a copy/paste typo, replace
Meter:Custom,
EL01SalesAHU03 PSZ-AC 1spd DX AC Clg Coil; !- Key Name
Air System DX Cooling Coil Electricity Energy; !- Output Variable or Meter Name
with
Meter:Custom,
EL01SalesAHU03 PSZ-AC 1spd DX AC Clg Coil, !- Key Name
This is likely be an extra caused by a semi-colon ";" instead of a comma "," finishing the input field on line 79649 of your IDF that precedes "Cooling Coil Electricity Energy" on line 79650 that the severe error message mentions.
Meter:Custom,
with
Meter:Custom,
