    |  1 |    initial version    |
I don't believe you can get output variables/meters in XML format. The OutputControl:Table:Style object only controls the standard tabular output reports.
However, you can get output variables in JSON or SQLite format if that helps by using the Output:JSON or Output:SQLite objects.
